D4DD коды ошибок
            Дата: Среда, 06.05.2020, 10:11 | Сообщение # 1
Постов: «4153»
P0088 COMMON RAIL PRESSURE EXCEEDS LIMIT
P0093 FUEL SYSTEM LEAK DETECTED
P0107 BAROMETRIC PRESSURE SENSOR -LOW VOLTAGE
P0108 BAROMETRIC PRESSURE SENSOR -HIGH VOLTAGE
P0112 INTAKE AIR TEMPERATURE SENSOR - LOW VOLTAGE
P0113 INTAKE AIR TEMPERATURE SENSOR - HIGH VOLTAGE
P0117 ENGINE COOLANT TEMPERATURE SENSOR-LOW VOLTAGE
P0118 ENGINE COOLANT TEMPERATURE SENSOR-HIGH VOLTAGE
P0120 PEDAL SENSOR NO.1 NOT OPEN
P0121 PEDAL SENSOR NO.1 NOT CLOSE
P0122 PEDAL SENSOR NO.1 SIGNAL LOW
P0123 PEDAL SENSOR NO.1 SIGNAL HIGH
P0182 FUEL TEMP. SENSOR LOW INPUT
P0183 FUEL TEMP. SENSOR HIGH INPUT
P0192 C/RAIL PRESSURE SENSOR SIGNAL LOW
P0193 C/RAIL PRESSURE SENSOR SIGNAL HIGH
P0194 C/RAIL PRESSURE SENSOR INTERMITTENT
P0201 INJECTOR #1 COIL OPEN
P0202 INJECTOR #2 COIL OPEN
P0203 INJECTOR #3 COIL OPEN
P0204 INJECTOR #4 COIL OPEN
P0217 ENGINE COOLANT OVER TEMPERATURE
P0219 ENGINE OVERSPEED CONDITION
P0220 PEDAL SENSOR NO.2 NOT OPEN
P0221 PEDAL SENSOR NO.2 NOT CLOSE
P0222 PEDAL SENSOR NO.2 SIGNAL LOW
P0223 PEDAL SENSOR NO.2 SIGNAL HIGH
P0225 IDLE SWITCH STUCK CLOSED
P0226 IDLE SWITCH STUCK OPENED
P0236 BOOST PRESSURE SENSOR INVALID
P0237 BOOST PRESSURE SENSOR SIGNAL LOW
P0238 BOOST PRESSURE SENSOR SIGNAL HIGH
P0301 CYLINDER 1 MISFIRE DETECTED
P0302 CYLINDER 2 MISFIRE DETECTED
P0303 CYLINDER 3 MISFIRE DETECTED
P0304 CYLINDER 4 MISFIRE DETECTED
P0335 CRANK SENSOR NO PULSE
P0340 CAM SENSOR NO PULSE
P0385 CRANK & CAM SENSOR NO PULSE
P0501 VEHICLE SPEED SENSOR(VSS) SIGNAL INVALID
P0502 VEHICLE SPEED SENSOR(VSS) INPUT OPEN / SHORT
P0503 VEHICLE SPEED SENSOR(VSS) FREQUENCY TOO HIGH
P0562 SYSTEM VOLTAGE LOW
P0563 SYSTEM VOLTAGE HIGH
P0601 CHECK SUM ERROR - FLASH AREA
P0602 QR CODE ERROR
P0606 CPU FAULT; MAIN CPU FAULT
P0607 CPU FAULT; WATCHDOG IC FAULT
P0615 START SWITCH SHORT TO BATTERY
P0627 FUEL PUMP CONTROL CIRCUIT - OPEN
P0629 FUEL PUMP SHORT TO BATTERY
P0704 CLUTCH SWITCH MALFUNCTION (M/T)
P0850 PARK/NEUTRAL SWITCH MALFUNCTION
P1091 FUEL SYSTEM #1 CYLINDER LEAK DETECT
P1092 FUEL SYSTEM #2 CYLINDER LEAK DETECT
P1093 FUEL SYSTEM #3 CYLINDER LEAK DETECT
P1094 FUEL SYSTEM #4 CYLINDER LEAK DETECT
P1120 PEDAL SENSOR SIGNAL INVALID
P1190 SUPPLY PUMP CONTROL VALVE(SCV) STUCK
P1217 SUPPLY PUMP PROTECTION
P1218 SUPPLY PUMP EXCHANGE
P1219 SUPPLY PUMP MULFUNCTION
P1231 EXHAUST BRAKE SHORT TO GROUND
P1232 EXHAUST BRAKE SHORT TO BATTERY
P1383 GLOW RELAY SHORT TO POWER
P1384 GLOW RELAY SHORT TO GROUND
P1616 MAIN RELAY MALFUNTION
P2146 INJECTION COMMON #1 OPEN CIRCUIT
P2147 INJECTION COMMON #1 VOLTAGE - LOW
P2148 INJECTION COMMON #1 VOLTAGE - HIGH
P2149 INJECTION COMMON #2 OPEN CIRCUIT
P2150 INJECTION COMMON #2 VOLTAGE - LOW
P2151 INJECTION COMMON #2 VOLTAGE - HIGH
P2293 FUEL PRESSURE REGULATOR 2 PERFORMANCE
P2503 CHARGING SYSTEM VOLTAGE LOW
P2504 CHARGING SYSTEM VOLTAGE HIGH
            Дата: Суббота, 01.04.2023, 15:52 | Сообщение # 2
Постов: «4153»
P0225 из практики ошибка по датчику положения педали газа. Первое что необходимо проверить, это грязь под педалью. Педаль при отпускании не выходит в "0" следовательно пара контактов на датчике положения разомкнуты, блок управления "видит" эту ошибку и выдает CHECK. Так же можно просто попробовать почистить контакты или "подкинуть" этот датчик с другого авто, он достаточно удобно расположен (на самой педали в салоне) и легко меняется.
            Дата: Суббота, 28.09.2024, 02:34 | Сообщение # 3
Постов: «2297»
P0219 Проблема с датчиком положения коленвала.Проверьте датчик коленвала на сопротивление, должно быть 125 Ом зазор между датчиком и задающим кольцом маховика 1,5мм
